tkappeler
Platinum Member
Our sump pump typically runs only during the winter months or when the water softener recharges. We do not have public sewer and do not really want to put it into septic field. Unfortunately, our yard is pretty **** flat after the first 50 feet or so from the house. We have a dry creek bed about 200' back from the house and would really like to get the discharge back to there.
During our home build, we used 150' of soft discharge lines but they froze up and I had to just use 50 and direct it to the side yard, which then turned into a snow covered swampy area until spring. I could put a hard discharge underground but it would only be about 6" below grade or it will be below the creek bed in the back. I am concerned about freezing and having the water back up.
Any suggestions on how to handle the discharge? Regrading the entire back yard is not really an options as it would take about 70 triaxles to adequately regrde the entire back. I could dig a dry well and line with rock but the high water table will probably keep it filled on it's own and then I would be back to the freezing issue.
I'm stumped.
I'm stumped.
