jaotguy
Veteran Member
step one ... make sure the hose inside goes UP higher than the creek level ... in stall a 1 way valve at the pump base .... add a T inside with a shutoff that goes through wall at a height higher than the snow level ( backup in case anything freezes ) ...
bury the pipe 4-5 feet deep until it gets near the creek ... then raise it up till it is about a foot( or so )higher than the creek bed ... make the end of the pipe slope down towards the bed , then slip a 4" piece of pipe over it before the last 10 feet to reach the creek .....
the pump should run , dump the water into the bigger pipe ( sloped and open towards the creek) and everything should drain that is exposed to the cold ... the 1 way stops it from back feeding into the house when the creek rises .. you can also add some 1-2" blue /pink Styrofoam above the pipe to 4" junction for added freezing protection....
