Sunpro gauges discounted on their websight
   / Sunpro gauges discounted on their websight #1
jdmar
Ohio
JD 5425 & 4300, Yanmar 1500
I went to the Sunpro websight to find some gauges to replace/backup the idiot lights on my YM 1500. Happily I found their triple gauge set (1 1/2" # CP 7997) in their "garage sale" section for only $9.99 (was $44.99). I e-mailed them and verified they are mechanical (not electrical senders) and they can be mounted individually out of their supplied bracket. So I ordered a set along with the needed metric adapters/etc.
I just thought others may be interested in saving a few buck too. Now I just hope they work when I hook them up!!
Sunpro sale gauges
Peter
   / Sunpro gauges discounted on their websight #2
I have sunpro gauges on at least two of my tractor.. and I think on a third... I've used their adapters and thin copper hookup line as well.
Cheap and good.. what a concept.. hope it catches on.
Soundguy
   / Sunpro gauges discounted on their websight #3
Thanks for the info, I just went and ordered my temp gauge and metric adapter from the garage sale.
   / Sunpro gauges discounted on their websight #4
What adapters do I need to add water temperature and oil pressure guages to my YM1700?
Eddie
   / Sunpro gauges discounted on their websight #5
The 1700 has an oil sender and an idiot light. You can either go to a straight gauge, using an oil line, or a new sender and electric gauge, or add a 'T' and keep the idiot light and add an oil pres gauge mounted in/under the dash.
I've even seen some plumbing with an elbow and a 'T', allowing use of the oem idiot light, and a gauge, threaded on right near the sender.. kinda reminiscient of the old IH/farmall method.. ad dthe oil gauge right at the oil canister/ block connection.
Soundguy
   / Sunpro gauges discounted on their websight #6
I guess what I was trying to ask is what size metric adapters I need for water and oil?
   / Sunpro gauges discounted on their websight #7
For the water temperature switch, you'll need an adapter for 16mm x 1.5mm. For oil pressure, you need an adapter 1/8 - 28 (BSP).
   / Sunpro gauges discounted on their websight #8
Thanks AllenP, Thats what I was looking for.
That was fast, I ordered tehm online the nighht of the 1st. With regular UPS shipping I got them on the 3rd!!! That's pretty good service!
Peter
   / Sunpro gauges discounted on their websight #10
Eddie
The Sun Pro.part no. for the oil and water adpt.kits is part no. CP7573 for the oil switch and CP7574 for the water temp.switch.
Don Wynn
2015 MACK CXU613 SLEEPER TRUCK (A43005)
2015 MACK CXU613...
2023 Stryker 36ft T/A Gooseneck Flatbed Equipment Trailer (A44571)
2023 Stryker 36ft...
2025 Mach Pro MPS330 UNUSED Skid Steer Loader (A47484)
2025 Mach Pro...
2006 Ford Escape Limited AWD SUV (A44572)
2006 Ford Escape...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A43005)
2001 KENWORTH T800...
2016 Infiniti QX80 4WD SUV (A44572)
2016 Infiniti QX80...
