Sunpro gauges discounted on their websight
/ Sunpro gauges discounted on their websight #1
jdmar
Ohio
JD 5425 & 4300, Yanmar 1500
I went to the Sunpro websight to find some gauges to replace/backup the idiot lights on my YM 1500. Happily I found their triple gauge set (1 1/2" # CP 7997) in their "garage sale" section for only $9.99 (was $44.99). I e-mailed them and verified they are mechanical (not electrical senders) and they can be mounted individually out of their supplied bracket. So I ordered a set along with the needed metric adapters/etc.
I just thought others may be interested in saving a few buck too. Now I just hope they work when I hook them up!!
Sunpro sale gauges
Peter
/ Sunpro gauges discounted on their websight #2
I have sunpro gauges on at least two of my tractor.. and I think on a third... I've used their adapters and thin copper hookup line as well.
Cheap and good.. what a concept.. hope it catches on.
Soundguy
/ Sunpro gauges discounted on their websight #3
Thanks for the info, I just went and ordered my temp gauge and metric adapter from the garage sale.
/ Sunpro gauges discounted on their websight #4
What adapters do I need to add water temperature and oil pressure guages to my YM1700?
Thanks
Eddie
/ Sunpro gauges discounted on their websight #5
The 1700 has an oil sender and an idiot light. You can either go to a straight gauge, using an oil line, or a new sender and electric gauge, or add a 'T' and keep the idiot light and add an oil pres gauge mounted in/under the dash.
I've even seen some plumbing with an elbow and a 'T', allowing use of the oem idiot light, and a gauge, threaded on right near the sender.. kinda reminiscient of the old IH/farmall method.. ad dthe oil gauge right at the oil canister/ block connection.
Soundguy
/ Sunpro gauges discounted on their websight #6
I guess what I was trying to ask is what size metric adapters I need for water and oil?
/ Sunpro gauges discounted on their websight #7
For the water temperature switch, you'll need an adapter for 16mm x 1.5mm. For oil pressure, you need an adapter 1/8 - 28 (BSP).
/ Sunpro gauges discounted on their websight #8
Thanks AllenP, Thats what I was looking for.
That was fast, I ordered tehm online the nighht of the 1st. With regular UPS shipping I got them on the 3rd!!! That's pretty good service!
Peter
/ Sunpro gauges discounted on their websight #10
Eddie
The Sun Pro.part no. for the oil and water adpt.kits is part no. CP7573 for the oil switch and CP7574 for the water temp.switch.
Don Wynn
/ Sunpro gauges discounted on their websight #11
Thanks Don,
Just ordered.
Eddie
/ Sunpro gauges discounted on their websight #12
Got my temp gauge and metric adapter kit 3 days after I ordered . Wow that is fast, It took all of 10 minutes to install. /forums/images/graemlins/grin.gif
/ Sunpro gauges discounted on their websight #13
got any pics of those installs? Let's see that creativity.
I put some on my tractor too - I'll try to post something.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
KUBOTA SR2790 SKID STEER QUICK ATTACH ROCK RAKE (A60429)
KUBOTA SR2790 SKID...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
