sunshine line by modern brush hog
   / sunshine line by modern brush hog #11
correct me if im wrong but couldnt the vibes be the fact that the blades are unbalanced - if you hit a rock it could unbalance the blades making them vibrate more
on my ride on if you dont balance the perfectly then you risk losing a filling from the earth quake of vibrations
mith
   / sunshine line by modern brush hog #12
A bent PTO shaft will cause it to vibrate. I'll mention that it is easy to bend the PTO shaft by raising the deck high with the tail set low.
   / sunshine line by modern brush hog #13
</font><font color="blue" class="small">( They really don't seem bent, just dull. The only real thing I see is that the blades didn't rotate freely on the stump jumper. I can see how this might cause it to vibrate but I'm just guessing.)</font>
It is my understanding that the blades on a rotary cutter should not really be sharp. I read somewhere that the leading edge should be 1/16" thick since a rotary cutter "shreds" rather than cuts.
On my old cutter I used to get strands of grass caught between the blades and the stump jumper and it would start vibrating. The blade(s) would then be "stuck", not swing freely.
Easiest way I found to clear them was to take a hose nozzle and blast them with water while jiggling the end of the blade up and down a little so the water could blast the trash out. That cleared it up every time. Of course be sure to shut the tractor down completely before sticking your hands up inder the cutter!
I tried WD40 on them but that didn't seem to help. If anything it just made the dirt stick to them worse.
Bill Tolle
   / sunshine line by modern brush hog #14
Needs 12 inch SUnshine offset shredder blades, HELP
   / sunshine line by modern brush hog #15
Blades have to swing freely or they will vibrate blade bolts wear out and need replacing also
   / sunshine line by modern brush hog #16
Take the blades off and see if it still vibrates. That should narrow it down for you.
   / sunshine line by modern brush hog #17
Thread is 10 years old
Toro Zero Turn (A50324)
Toro Zero Turn...
Adams 6Ton Hydraulic Lime Spreader (A53473)
Adams 6Ton...
TURBO SAW SKID STEER ATTACHMENT (A53843)
TURBO SAW SKID...
33ft Dovetail Flatbed Trailer (A53473)
33ft Dovetail...
2013 Vermeer BC900XL Towable Brush Chipper (A52377)
2013 Vermeer...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
