Super Cheap Lawn Mower Blade Sharpening Jig
   / Super Cheap Lawn Mower Blade Sharpening Jig #1
The Suburban Farmer
Northern Virginia
Deere 2320
Well, after trying to mow yesterday and getting less than an ideal cut, I remembered to check my blades and they were dull, dull, dull. Chipped, too. I THOUGHT that I'd sharpened them at the end of the fall season, but I guess I didn't.
I had a lot of nicks to take out and wanted to make sure I kept a consistent angle, so I rigged up a jig using some scrap lumber and an old unused Harbor Freight angle grinder. I measured my blade angle and it was somewhere around 30 degrees (but hard to tell since they were beat to heck) so I fabbed this with a 30 degree angle. The nice thing is that I can easily make-up another holder using 40 or 45 or anything else I need when the time comes.
Not a high-dollar piece of art, but it was functional and put a great edge on all 3 of my blades in less than 10 minutes. Back-honed the blades with a stone to remove a few burrs and now they look good as new. Sure beats paying $200 for a specialized lawn mower sharpening tool.
I'm not sure if this will work for mulching blades, though. This relies on having a flat and relatively straight back edge on the blade to work.
   / Super Cheap Lawn Mower Blade Sharpening Jig #2
That ought to do it. Do you balance the blade when you're done? I've been balancing mine on a hacksaw blade and that's been good enough (I think).
I dress them a few times without removing the blade from the mower - by using the top of the grinding disc. But you have to pay attention to the fabric ontop of the disc, if you lose more than just a little you should understand that fabric ontop could be holding your stone together. So keep it down to a minor dressup if using the top of the disc. You don't want a rounded edge ontop of the disc.
   / Super Cheap Lawn Mower Blade Sharpening Jig #3
Awesome jig. I'd also balance the blades after taking out chips and notches. Being off even a bit is enough to cause premature wear and failure on the spindle bearings. Replacing one spindle is generally $100+ for all the decks I've ever messed with, and I've never seen a deck all the blades couldn't be replaced for MUCH cheaper. Seeing as I'm always working with limited time, I don't buy a mower without buying a set of extra blades. I've found it best to have a spare set of blades sharpened and ready to go. When I have time in the schedule to mow, I don't have additional time to spend sharpening blades (rather do that during bad weather when I can't cut grass). Anytime I don't get a satisfactory cut, I take the ten minutes to swap blades and go back to work laying the old set aside for a rainy day. I think my next rainy day will be spent making a jig similar to yours. My bench grinder has an adjustable plate to help control the angle of your stock to the wheel, but it is very imperfect of a solution. I think your setup would create a flatter more precise edge.
Yes, I balance them as well using one of these little things that I got on Amazon for like $3 a while back:
When I took out the big nicks, they were a bit out of balance, so I ran them through the sharpening jig until they floated perfectly level on the balancer. Now, hopefully, if I do the same number of passes on each side, they should stay in balance for touch up.
   / Super Cheap Lawn Mower Blade Sharpening Jig #5
thats what I use.
   / Super Cheap Lawn Mower Blade Sharpening Jig #6
I, too, have that same balancing gadget.
   / Super Cheap Lawn Mower Blade Sharpening Jig #7
What is the significance of the angle on the blade and what can one expect when going one way or the other(-30 or +30 degrees)?
2012 MACK GU713 TRI AXLE DUMPTRUCK (A43004)
2012 MACK GU713...
72" Skid Steer Sweeper JCT Standard Flow Sweeper (A42203)
72" Skid Steer...
Avant 528 (A42021)
Avant 528 (A42021)
5T Excavator Manual Spring Loaded Pin Grab Coupler (A42203)
5T Excavator...
Vermeer Navigator Directional Drill and Trailer (A44391)
Vermeer Navigator...
2005 Ford F-350 4x4 Pickup Truck, VIN # 1FTWW31P15EB55494 (A44391)
2005 Ford F-350...
