Super nice Kubota excavator
   / Super nice Kubota excavator #61
Good stuff Rustyiron, but maybe some background and context would be useful here. I have 2 main uses
Cutting high brush and digging out rocks. So a SS would Hebb helpful, but less ideal than a mini ex.
Almost all my brush cutting falls into 2 categories: pond banks (steep) and field edges (branches). Skid steer not useful here.
While breaking my back cutting field edge branches 5-25 off the ground with a pole saw, I realized I needed a cutter with an arm that can reach up high and grind-off branches.
I also do 2 different customers annual large cuttings around streams and ponds. These are good paying jobs. However, I have to stand in canals or on pond banks to cut them with weed whacker and saw blade for weeks to complete them. The pond has a flat-top berm which a mini ex could be driven on. With properly weighted smaller mulcher head, I could sit in cab and cut pond on one side and canal on the other. I could also sit on dry ground and reach over swampy land with dipper stick. This would cut my weed whacking task down by 80-90% and allow me to keep the contract well into my older years.
Rocks:I cut about 250 acres of hay fields. Some fields have significant rocks and a few stumps which are deadly expensive to hay cutter. Removing them lowers risk of damage and injury.
There are other uses. I still build an occasional construction project where a foundation or footings are needed.
I have seen some KX161 and U45 models that are fairly affordable, but the KH28L was really clean and cheap. However, if the aux circuit doesnt have any GPM, whats the sense in buying it.
Also, I have a 200HP Massey Ferguson 7495 I could mount a front mulching mower on, but I don’t really have a lot of brush in open space to cut. Its mostly field edges.
It must be horribly time consuming/tiring doing the work in those pix manually!
   / Super nice Kubota excavator #62
40 K, brand new. That included the quick attach setup, a 2ft digging bucket, ripper tooth, and a 3ft grading bucket. I know... it's more than the other...
New? And what size?
Yeah it sucks, fried. A mini with a mulcher head would be great for this aging body. I’ve been doing it for years. Each year it takes a little longer.
Seller texted me this morning that someone said they’re coming to probably buy it.
   / Super nice Kubota excavator #67
I was looking at a KX040. The dealer quoted $53,000 base model. Add $7,000 for a cab, add $2500 for hydraulic thumb, add 2500 for an angle blade. They’ve got a 1200 hour used one with a cab, hydraulic thumb, and 4 way blade for $35,000.
   / Super nice Kubota excavator #68
KX040 Nice size machine.........
   / Super nice Kubota excavator #69
I looked at the kx 91 and the 040; but for my personal use I just couldn't justify the extra cost. Mine at 6,000 lbs is amazing when compared to a tractor/back hoe, but has it's limitations compared to the 10k lb machines. But, it sure is sweet to run and every minute on it is productive and fun.
BTW, that isn't a bad price for that sized machine. All depends on how it was maintained.
   / Super nice Kubota excavator #70
I really wanted an 80 but they’re better than 100g for a new one. I looked at the 57s to but they’re not much cheaper.
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
