surface rust - how to clean
   / surface rust - how to clean #1
RancherSam
Hays County, TX
Case IH JX95 4x4
I have an engine hoist/lift with a cylinder piston that has been in the open/extended position for a while and it has some surface rust on it. How do I clean it up to make the piston look new and shiny again? Thanks for all the replies and happy new year.
Sam
   / surface rust - how to clean #3
Not sure if this is the exact term, but we always used emory cloth. It's real similar to sand-paper.
   / surface rust - how to clean #4
i would be against using emery cloth might scratch the surface and cause the cylinder and cause it to leak.go to walmart or a good auto parts store and get a product called never dull it is a wooding polish it is made by eagle one.it is not very expensive but it truly does an amazing job on surface rust.
   / surface rust - how to clean #6
I use 400 grit and wd40 which keeps the sandpapers bite down on things like that.
   / surface rust - how to clean #9
I'd use the steel wool and then a product like "The Must for Rust" that has phosphoric acid in it to protect the metal from rusting.
The 400 grit and the scotch brite pads can take off a fair bit of metal if you are not careful.
   / surface rust - how to clean #10
green scrubing pad and wd40. Dont use to much pressure.
2025 Wolverine TL-12-72W Hydraulic Rotary Tiller (A47484)
2025 Wolverine...
2016 KOMATSU WA-470 FRONT END LOADER (A43005)
2016 KOMATSU...
2025 Wolverine TF1-66-4000G Adjustable Pallet Fork (A47484)
2025 Wolverine...
Honda GX 240 Small Gasoline Engine (A47484)
Honda GX 240 Small...
2025 Wolverine PFF3-13-45W Pallet Fork Frame (A47484)
2025 Wolverine...
2025 KJ K0720 UNUSED 20 ft. Bi-Parting Metal Gates (A47484)
2025 KJ K0720...
