surface rust - how to clean
   / surface rust - how to clean #1
RancherSam
Hays County, TX
Case IH JX95 4x4
I have an engine hoist/lift with a cylinder piston that has been in the open/extended position for a while and it has some surface rust on it. How do I clean it up to make the piston look new and shiny again? Thanks for all the replies and happy new year.
Sam
   / surface rust - how to clean #3
Not sure if this is the exact term, but we always used emory cloth. It's real similar to sand-paper.
   / surface rust - how to clean #4
i would be against using emery cloth might scratch the surface and cause the cylinder and cause it to leak.go to walmart or a good auto parts store and get a product called never dull it is a wooding polish it is made by eagle one.it is not very expensive but it truly does an amazing job on surface rust.
   / surface rust - how to clean #6
I use 400 grit and wd40 which keeps the sandpapers bite down on things like that.
   / surface rust - how to clean #9
I'd use the steel wool and then a product like "The Must for Rust" that has phosphoric acid in it to protect the metal from rusting.
The 400 grit and the scotch brite pads can take off a fair bit of metal if you are not careful.
   / surface rust - how to clean #10
green scrubing pad and wd40. Dont use to much pressure.
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
1995 Rinker Captiva 190 (A55315)
1995 Rinker...
1633 (A57192)
1633 (A57192)
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
2017 FORD F-450 XL BUCKET TRUCK (A57192)
2017 FORD F-450 XL...
Metal Bigfoot with Flag Lawn Art (A55853)
Metal Bigfoot with...
