Backhoe swing cylinder loose
   / swing cylinder loose #1
Douglas
Iron Mountain, MI
Hello: I have a john deere 8b backhoe on a 950 tractor. Doing some excavating and discovered that one of the two swing cylinders is loose. It is attached by a long threaded rod with lock nuts compressing a spring. Do I just tighten till secure? Tried to look up this topic (and even downloaded a so called technical manual) without an answer. Probably a simple question. Has anyone else had this issue?
   / swing cylinder loose #2
Before you do anything be sure that the rod eye bushing and barrel eye bushing are still intact and the cylinder and rod will not move-if the cylinder rod eye bushing is shot or if the barrel eye busing is shot you have to replace them.
The pins should be tight as well and if they are not .......... you have to replace them too.
I took a closer look today and found out that the backhoe can be swung side to side (perhaps six inches) and both pistons will move in and out a bit.. Tried tightening the piston mount nuts equally on both sides and it seems that the free play in the backhoe swing is some better but NOT tight..(wish I had a tech manual)
Thanks for the response. Bushings are tight. Just heard from JD and will call for a serial specific tech manual in the morning and see if this is normal or not.
Life Proof SPC Luxury Flooring with Soundproof Membrane (A53425)
Life Proof SPC...
2020 HINO 268 26FT NON CDL BOX TRUCK (A56138)
2020 HINO 268 26FT...
Informational Lot - Financing (A55302)
Informational Lot...
2019 BOBCAT T450 SKID STEER (A52706)
2019 BOBCAT T450...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A55852)
2007 Ford F-550...
Ammco Brake Machine (A55758)
Ammco Brake...
