sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,849
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Is this hydraulic fluid or transaxle fluid?
I'm glad I saw your post sixdogs because I've been thinking about doing the same thing to my B7800. did you use the low viscosity hy gard or the regular hygard.
Last time I did my hydro oil change I noticed on the Kubota oil pail that the Kubota sudt met the requirements of john deere spec j20d. So I assumed the oils were equivalent. this was before the advent of sudt2.
Maybe there is a reason why the Kubota oil is a good 30% more expensive than the john deere oil.
I used the regular HyGard since I think the LoVis Hygard is just thinner and not synthetic. Shop around and you can find SUDT2 cheaper. I found in the $85 range.
Find my B7800 thread on using regular HyGard as opposed to SUDT2. I wasted my $$, I feel by using regular dino oil and the synthetic SUDT2 performed much better. On my M6800, I had 5 hours on a fresh trans fill and decided to switch back to SUDT2. The hydraulic shuttle shift was not acting right and after the change was back to normal.
