synthetic lubes other than crankcase oil
   / synthetic lubes other than crankcase oil #31
ok.. one more question on the crank sensor.
When I got the truck I asked the dealer about it due to what I have read here before about them.. he said he had changed it when the truck came in.
now.. that said.
do these things fail that often? Is it worth it for me to carry a spare?
is it something I can change onthe side of the road with a ratchet set or wrenches?
if yes to above questions.. then anyone got a pic / location on my 7.3 so I can get an idea of what would be needed to change it.
or is this an item that would take more work/tools/time to fix than what i would be carrying with me.
heck.. I'm carrying spare 'other' things.. if this sensor is so crummy and not expensive.. sounds like something else to have.
is this a dealer only item.. or something I can get at napa?
thanks
soundguy
The new version of the CPS is grey and is way superior to the old black one in terms of dependability. Hopefully that's what your mechanic put in. They are 38$ at the ford dealer but you can buy the CPS at NAPA as well plus I would imagine other parts places. Mine would cause the engine to momentarily shut off, especially when the intermittent wipers would fire. I suspect something to do with EM interference since the sensor is a magnetic pickup for the cam postion but who knows.
The old black ones failed that often, so often that you carry a spare in the truck. I carry a new grey one in the glove box out of habit and since I didn't yet know to trust the new grey one. They aren't big or expensive so why not? Given the new grey one's track record I wouldn't feel bad about giving it to a guy on the side of the road broke down with a bad black CPS and might not replace it.
You can change it on the side of the road easily. The sensor is located right on the front of the engine. if you are looking at the harmonic balancer(main crank pulley) from the front the sensor is located at the 10 o'clock position. You will access it from below on the dside of the front of the truck. A 10 millimeter bolt holds it in so all you need is a basic socket set. The sensor has an o-ring seal so you just pull the old one out and put the new sensor in.
I really like the new grey sensor and I think Ford finally fixed it.
sweet.. so wrench or ratched laying on the side of the road sounds doable.
and for clarification.. this is a cam position sensor? yes? ( not cranl as I said earlier? )
thanks for the info.
soundguy
   / synthetic lubes other than crankcase oil #33
I bought my CPS replacements & spares at International and they are green and were 13 bucks. I have replaced one in my 350 and 1 in my 450.
With the change to syn trans fluid my temp while towing went down 10 degrees, never see over 190 now.
can't wait to see what mine does.
soundguy
   / synthetic lubes other than crankcase oil #35
CPS really acts as a camshaft position sensor since it is looking at the cam gear to sense and time the rotation. These things have been failure prone for so long that any parts place should be very familiar with a "CPS" for a superduty diesel.
Not aware of a green CPS. There was a blue and a purple that you could buy for other IH engines.
Side of the road for sure. The engine block will be warm of course. You will need a 3/8 ratchet, the typical 3 inch extension, and a 10mm socket. All should be in your 5$ socket set behind the seat from HF.
my replacement was a 'grey' one.
got the tools in the tool boxes.. so.. should be set.. likely won't fail now that I have a spare.. :)
picked up a spare headlamp and tail lamp and trailer lamp too..
soundguy
Charlotte County (A50323)
Charlotte County...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
