crashz
Veteran Member
To preserve your investment in the extended warranty, I would document every maintenance interval and strictly follow the owners manual. If it calls for an oil change when prompted by the oil monitor, then do so. And if it regularly indicates an oil change is needed before 6000 miles, then stick to a good off the shelf conventional oil. Keep a record of every maintenance item and have a copy of your maintenance logs (never the original) availble for the dealer and warranty company any time there is a claim. These warranty companies are just like insurance companies and will treat you the same when a warrranty issue arrises. I've had my share of run-ins with them and the only thing that ever counted in my favor was well documented, strict maintenance. Learned it the hard way after paying for s short block that was under my extended warranty and later recalled for gasket failure.
Most modern oil life monitors measure ambient temps, operting temps, operating time, engine rpms, fuel usage and airflow and then compute a theoretical oil life based on the recorded data. They cannot indicate the amount of suspended solids, total base number, viscosity or contamination from fuel or coolant leaks. The also cannot tell the difference between synthetic and conventional oils. So putting synthetic in a vehicle will not make the oil life monitor extend the drain interval, baring any changes in driving habits.
