Synthetic oil
   / Synthetic oil #11
Some say not to use synthetic oil until the engine is broken in because it does not have enough friction. But there are many vehicles that come with synthetic oil as the factory fill.
   / Synthetic oil #12
That used to be the case. Syn oil was so efficient at lubrication that rings wouldn't seat. Manufacturing has gotten better, and tolerances tightened. The engines that come with syn oil from the factory are held to tolerances that don't require break in. It used to be that you were advised to do the first oil change at 500 miles. Things have gotten better since then.
   / Synthetic oil #13
Thank you LWG, I remember the days of 500 mile break in oil.
   / Synthetic oil #14
I switched to synthetic in all my vehicles, all are 9-10 years old. Not sure if it was a good move or not, seems to be using more oil. I wa told by someone that now I can't go back. Anybody know if this is true, that once you switch to synthetic, you can go back to dino? tks
   / Synthetic oil #15
I have done the same and much older. So far no problems. It was about 5 years ago on the 454 TBI in the MH at 92K miles and at 109K it still does not leak and still runs 3000 miles and only be a quart low at change time.
You can mix, blend, reverse usage at will. I have read newer spec'ed dino oil is about 25% synthetic already.
   / Synthetic oil #16
I switched from Rotella T 15-40 to synthetic Rotella 5-40 in my 90's B7100. The tractor starts much easier and quieter. Has not leaked a drop.
   / Synthetic oil #17
That incorrect advice is among the top ten wrong things people say about synthetic oil. Check the oil manufacturers web site.
1271 (A50490)
1271 (A50490)
Year: 2020 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 190,820 Plate: Body Type: 2 (A51692)
Year: 2020 Make...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
