Tach, Temp, and Hour gauge not working
   / Tach, Temp, and Hour gauge not working #1
ricksalisbury01
I have a CK35 Manual and have been using it a lot to back fill a new basement addition. The tractor was bought new in 2009 and has 233 hours. It has always been stored inside a building with a concrete floor except for the last two months. That said, two days ago, the Tach, Temp gauge, and Hour meter stopped working, started again after about ten minutes, and has not worked since. I checked all the fuses, and the connections at the "Display Unit," and all seemed good. The fact that it worked, then went back out suggests to me a loose wire. Has anyone else had these issues, and how was the issue resolved? Thanks
   / Tach, Temp, and Hour gauge not working #2
Try wiggling the connector on the display unit. That's a bigger box on the firewall near the center. If the connections there are "iffy" a shot of contact cleaner should do the job. Alternatively, there may be a wire problem in that vicinity.
   / Tach, Temp, and Hour gauge not working #3
Definitely sounds like loose wire or bad ground - but beyond that I have no suggestions.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
