dusty3030
Veteran Member
- Joined
- Jun 4, 2008
- Messages
- 2,273
- Location
- West TN
- Tractor
- Kubota MX5400 Cab, Kioti NX6010 Cab, Kioti RX7320 PS/ Cab, Kubota M7040 HDC, John Deere 2355, Kubota U35-4, John Deere 317G
Good choice. Easy to keep running yourself for a long, long time.
Most of them come now with a plastic safety slide. It works just fine; however, if you use it alot and it gets wobbly order the metal replacement - an oe part - for the 590. It will last forever.
Ejector is held on by a screw. This is good, if it ever breaks (not likely) it is easier to replace then a Remington 870 which is riveted. Down side is screw has a tendency to get loose. Don't gorrila it tight since it is aluminum reciever, just make sure it is snug whenever you get it and then every few thousand rounds, no big deal.
Recoil, not every shotgun fits every person. If the stock is too long recoil seems worse. Don't be afraid to cut it down. I could walk you through it, its easy. If the stock recoil pad seems hard there are plenty of real nice inexpensive prefitted aftermarket pads that are nice.
Good luck and good shooting! That gun should last forever with minimal care. Don't ever never try to take the trigger assembly apart, just take it out, hose it out with rem oil aerosol, blow dry with a air comperssor and put it back in. Shouldn't need to totally field strip and clean it unless you get it all wet or every 1,000 rounds or so, whichever comes first.
