Tajfun Logging Winch, clutch Adj.?
   / Tajfun Logging Winch, clutch Adj.? #1
sparkkky
Oklahoma
Kubota B21
Hello, can anyone give me any pointers on this?
   / Tajfun Logging Winch, clutch Adj.? #2
Can you contact the company, a dealer or USA importer via email? I did some research on this brand last winter and located a dealer in Marshfield, WI, about 160 miles away. My tractor folder is out at the camp, so don't have info on who I contacted. If you haven't done a Google search, it may be worth a try.
penokee /forums/images/graemlins/smile.gif
Ps: Did you consider a Farmi? I haven't purchase yet, but have it boiled down to Farmi or Typhoon. What helped you in picking a brand? Thanks. /forums/images/graemlins/smile.gif
   / Tajfun Logging Winch, clutch Adj.? #3
Try this page
However, if you do a google search you will find a lot more pages about that winch.
Hope this helps.
murph
Been talking to Anders, the man I bought the winch from, and he is suppose to confirm what the manual is saying. If you turn it the wrong way you have to pull the drum.
Yes, I would buy a Tajfun again!
   / Tajfun Logging Winch, clutch Adj.? #5
My manual says to move the adjusting nut to the right for more tension. Only by turning it to the left could you loosen it to the point of having problems with the clutch plates.
Is the clutch slipping? I have pulled 10 cords of hardwood firewood and around 2600 bdf of logs plus some other pulling chores and it is still pulling strong.
I did have to make a small adjustment on the brake power about half way through the logging described above. The manual was right on for that adjustment.
Let us know how you make out
Dave
Looks like the set screw came loose and it backed itself off. Seems like I am good to go now!
   / Tajfun Logging Winch, clutch Adj.? #8
Great Sparkky, the simple fixes are the best /forums/images/graemlins/grin.gif
Dave
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
8-Shank Cultivator (A52128)
8-Shank Cultivator...
UNUSED AGT QUICK ATTACH HYD HAMMER (A51244)
UNUSED AGT QUICK...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
