We started with a 10hp home store unit. It was pretty much useless. And it was hard to start- there was no clutch so you were pulling over the engine and the
chipper rotor. We then got a 16hp tractor and a 4.5" PTO
chipper. This
chipper has manual feed, or self-feeding. When it grabs something it sucks it in FAST. You better not be holding on to the branch or standing anywhere near when it does. It could pull your arm into the chute or whack you on the head.
Then we got a 37hp tractor and a
Woodmaxx 8H hydraulic feed 8"
chipper. That works so much better and is much safer. The chips it makes are smaller than the ones from a big tree service
chipper so they rot faster. Which can be good or bad depending on what you are doing with them.
However to put chips down on roads or paths, you'll need more equipment. I use an ATV dump trailer to chip into and then to carry the chips to the roads I want to lay chips on. I have yet to come up with a good machine assisted way to distribute chips so I shovel them out and spread them by hand. That does not scale to long paths.
If you have paths wider than a tractor width you can use a tractor to spread the chips. Chips in a pile are not as easy as dirt to scoop up with the loader. The tree service chips are harder than the chips from my PTO
chipper. I can do it, especially with a tooth bar, but its more difficult. Chips also do not spread as easily as dirt. You may want different tools than dirt working tools like a loader and box blade.
The pto
chipper on the 37hp tractor takes care of brush and tree parts much better than the smaller units I've had. But you'd have to have a lot of tree parts, and a lot of time, to make a significant amount of chips. It takes time to process tree parts into chippable piles and feed the
chipper.
You might look into getting chips from a tree service. Often they will be happy to dump chips on your property instead of driving them to the dump and paying to dump them. You'll need a way to move them though. But you can get a lot of chips with no effort on your part.
