Taller tires on a BX?
   / Taller tires on a BX? #11
Haywire said:
Anyone ever put taller tires on a BX to get more ground clearance? I keep forgetting to look to see how much room I have between the rear fender and the existing tire.
Ian
I had a BX 22 for 6 years and it did every thing I ever asked it to. Those tractors are fantastic for their size. Mowing was actually enjoyable. The people who snub them just don't have a clue
   / Taller tires on a BX? #12
This is one of the problems w/ subcompacts that people don't learn until they get. I many times try to discourage people from buying a subcompact because it is just too small and they don't realize it's downfalls and limitations until it's too late.
There are thousands of us who have a different take. My BX is perfect for my needs. It may be too small for your needs, but to say it is just too small as an absolute truism?
Politics and religion have become a realms where there is no room for discussion. Everyone is certain he/she is the font of absolute truth. I do not want tractor talk to become the same.
   / Taller tires on a BX? #13
Dude, hating on BX's on this board ain't gonna make many friends. :smiley_aafz:
   / Taller tires on a BX? #14
I bought a set of BX1800 wheels w bar tread tires for my BX1500. Had to space the fronts out about 1/2" to clear the steering arms. Rides better. More traction. No interferance with the 54" mower. Slightly more front lead ratio just makes it handle better. + + + as far as Im concerned.
larry
   / Taller tires on a BX? #15
I have found just about anything can be done if you want to spend enough money and make the necessary modifications. Whether you would be better or worse off is the question.
I am one of those who thinks the BX is the perfect tractor for my needs and many others; I am bemused by those who look down on it. Yes, we have several different tractors, but our BX really cannot be replaced by any of them.
   / Taller tires on a BX? #16
Ian
Given all conditions I'd suggest buying a B-2620!
   / Taller tires on a BX? #17
Yeah the anti-sub comment was a little off, don't suppose since that was coming from a Kioti dealer, who doesn't offer a sub-compact......naaahhh couldn't be.:laughing:
My BX24 fits me perfectly right now.
Mainly because I have to transport it back and forth to my remote camp.
Now if I lived there I might have gone a little bigger although I found weaving through the forest is a must and smaller is better for my use right now.
One other thing to consider- even if larger/taller tires fit you've then screwed up the gearing for pulling power..I'm sure Kubota took tire diameter into account when selecting drive ratios.
   / Taller tires on a BX? #18
I sure to like my BX 2660. It does everything I need from a small tractor.
I do wish it had more ground clearance under the front hubs though.
   / Taller tires on a BX? #19
The bx is a great mower and tractor but a better combo would be a B series for real work and a dedicated 5 foot front cut mower. Depends on if you have the money for both or not
   / Taller tires on a BX? #20
I guess it depends on your definition of real work, all our tractors from the BX2660 to our M8540 do real work in my opinion.
Kawasaki NR (A50324)
flooring (A55758)
flooring (A55758)
pressure washer (A55973)
pressure washer...
2014 Ford Mustang Coupe (A55853)
2014 Ford Mustang...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
