Tap size question
   / Tap size question
Well heres an update for anyone that snaps off a fitting.
First of all dont drill the fitting out. That was a bad move. They sell reverse dill bits that I may have been able use or an easy out (I have never had any luck with easy outs).
I discovered that the threads are 3/8 Pipe threads so that is NPT I believe.
I ended up dremeling the the stuck fitting down until it was paper thin and then running a tap down thru the existing threads. They people at my local Napa store are very helpful with this kind of stuff.
As for cleaning out the ram it is all taken apart and it is easy to clean it up.
A tip I will try on the next one a person showed me. They took a nut that was slight larger than the broken fitting but smaller than the actual threaded hole, then they welded the inside of the nut to the broken fitting.
   / Tap size question #12
That can work on broke studs too.. weld a nut to the stud. etc.
In your case of a hollow fitting.. just be carefull about the penetration and you should be good to go. The weld will probably shrink the fitting too...
Soundguy
   / Tap size question #13
These are also handy...
   / Tap size question #14
Those stud pulers offer lots of mech advantage.
soundguy
   / Tap size question #15
If you have the cylinder off, you can also apply heat to help loosen things up. I love my torch.
2018 John Deere 325G (A47477)
2018 John Deere...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2020 INTERNATIONAL RH613 MID-ROOF SLEEPER TRUCK (A53843)
2020 INTERNATIONAL...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
