Tapping into tractor hydraulics
   / Tapping into tractor hydraulics #11
My bad. Thought it looked like a loader valve.
Where do they tap loader hydraulics for that tractor if it had been equipped with one?
They had a dual selective control valves that bolted on between the flow divider and the rock shaft valve. In the pic the dual selective control valves are circled in yellow and the flow divider is orange. They want 1100.00 a piece for them plus control linkage and lines from the dealer. An aftermarket valve was a no brainer to me
   / Tapping into tractor hydraulics #13
If you hook directly into the pump line you won't be able to steer while you're moving the blade. Seems like you could hook a hose to the rock shaft outlet on flow divider and the return hose to the end of the hard line. You might have to bend it a little, or not.
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Deere 35P (A53317)
Deere 35P (A53317)
1991 Snowco Trailer (A59814)
1991 Snowco...
Sedan (A59231)
Sedan (A59231)
Ford 8510 (A53317)
Ford 8510 (A53317)
