jwstewar said:
I'm not an electrician and don't know much about the "rules" of electric so I hate to argue with you Jim, but I've seen a bad ground blow fuses.
Jim, you aren't arguing with me, you are just not accepting that Ohm's Law
is a law. What you did to "fix" the problem was not really the source of the problem. It contributed to a blown fuse, but the problem was a circuit that pulled more current than the rated value of the fuse. If you had increased the value of your fuse, the problem would have gone away too.
When cold (off) a lamp's filament has less resistance than it does when it is on. As the filament becomes hot, the resistance rises. There is an initial surge of current that reduces as the filament heats. The properly fused circuit will have fuses well above the maximum draw of the lamps when cold.
Some fuses are called slo-blow type because they can take short surges of current above their rated value. A continuous current above their rated value causes them to blow.
If you have a lighting circuit that pulls current at almost the fuses limit when hot, what do you think will happen if you repeatedly make and break contact? What happens is the average surge current through the lamp's filament exceeds the fuses maximum rating and it finally blows. This is most often seen as a delayed reaction.
I think when you added the trailer, you were right at the limit of the fuse. Because of the intermittent ground contact, the lamps never heated up and their resistance never rose to the rated value when on full bright. As a result, their lower resistance pulled too much current. By design, a bigger fuse was needed. If you had never added a trailer, bad connections on the truck would never have caused this problem.
So, I'm saying that what you did had the effect of not blowing the fuse, but that same fuse was not very "happy" when you added the trailer, not even the new one after you fixed the ground. You were always just a few milliamps away from another blown fuse.
