TC 35 starving for fuel
   / TC 35 starving for fuel #11
Messicks has them in stock, so it is likely a common problem. The pump is insert mounted into the engine, and runs of the cam shaft, I think.
I caused my failure by running the tractor on a steep incline, which plugged the fuel filter, yet kept the tractor running(pumps shouldn't run dry). It never ran right after that.
Chris
I thought the bowl was gravity fed. Is the auxiliary fuel pump tied into the vent hose coming off the top of the fuel bowl assembly?
   / TC 35 starving for fuel #13
yep. It is the hose on the outlet of the fuel bowl, which leads to the fuel pump, and then back to the tank. If that pump isn't working, the tractor won't run going uphill.
chris
Well that makes perfect sense.
I will order one up and let you know how I make out.
Thanks for you help dynasim
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2024 Sky Jack SJ45 AJT Man Lift (A51573)
2024 Sky Jack SJ45...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
2012 KENWORTH T600 SERIES (A52472)
2012 KENWORTH T600...
