TC-40D HST PTO Hard to engage
   / TC-40D HST PTO Hard to engage #1
catfishsteved
Texas - Ellis County
TC40D
My PTO has become harder and harder to engage/disengage. I have cleaned the linkage with no better results. Is the problem internal? Any ideas? Thanks.
   / TC-40D HST PTO Hard to engage #2
Your problem is most like likely the plastic bushings and shaft that the pto lever is mounted to. When the shaft rusts the plastic bushing will bind.
You can determine if the shaft and bushing are binding by wiggling the pto lever side to side. By comparing the play with another lever you will see there is a certain amount of play
Mike
   / TC-40D HST PTO Hard to engage #3
Steve, Mike (Spicer) is correct. All the levers on the left side pivot on the same shaft. Looking at the illustration below, that pivot shaft is item #14. When I took mine apart, the shaft was corroded. Cleaning that up and adding a little lube should take care of your problem. To get at the shaft, you'll need to remove the left side plastic console. It's bolted on from underneath the fender and you can even get to the bolts without removing the wheel. With the console off you can unbolt one bolt on each end of the shaft and slide it out so it can be cleaned. That's what I'd suggest as a first step and probably will be all you need.
Deere 410L (A53317)
Deere 410L (A53317)
2003 Toyota RAV4 SUV (A55853)
2003 Toyota RAV4...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2022 Padget Morris Electric Mobility Scooter (A55853)
2022 Padget Morris...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
