brain55
Veteran Member
Electronic Hydraulic Shuttle Shift. The fwd/rev shuttle function is absolutely controlled by electronics. All the fwd/rev lever controls is an electronic switch that sends a signal to the EHSS controller with controls the fwd/rev servos that control the hydraulic clutch pack. The clutch pedal also has an electronic clutch switch and a cable that attaches to a dump valve spool that moves about 1/10 of an inch to cut flow to the clutch pack. The only problems I had with the electronics on the shuttle controls was that when the wiring would get wet the shuttle wouldn't function. Filling the back side of all of the harness connectors with silicone took care of the problem.
Brian
Brian
