TC29D throttling down
   / TC29D throttling down #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
Last week my TC29D started to throttle itself down. I run the RPM's up to 2500 and you can watch the throttle itself slide back down to about 1800 RPM's. I look the cable over and the only thing I can see is the spring on the pump that helps pull it back. I can not see up under the dash without taking it all apart to see if there is a tightening screw there. Has anyone else had this experience? And why would the cable get looser after two years. I would think it would get dirty and tighter?
murph
   / TC29D throttling down #2
There may be a friction washer or nut at the throttle lever that needs some attention
Well first it looks like I put this in the wrong forum, Buying instead of owning/operating.
Anyway I guess I will have to take the dash apart to get to the throttle and see if there is a washer there.
murph
   / TC29D throttling down #4
You have to take the lower part of the dash apart (black plastic). There are friction disks, loosen a nut and you're all set. I have to do this one of these days. /forums/images/graemlins/crazy.gif
   / TC29D throttling down #5
Someone was having the same problem awhile back and posted for help. I'm pretty sure it was in the New Holland Forums. It was explaining something about a tensioning screw or something similar to what MikePA has suggested. Good luck Murph! /forums/images/graemlins/smile.gif
   / TC29D throttling down #6
Murph here's the thread that I was talking about, but by now you probably have it figured out! /forums/images/graemlins/smile.gif Here
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2016 Ford F-150 XLT Pickup Truck, VIN: 1FTEX1EP4GFD61185, Extended Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2016 Ford F-150...
AGRICO FERTILIZER SIGN (A58374)
AGRICO FERTILIZER...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
