tc30 no-start with glow line hooked to ignition sw
   / tc30 no-start with glow line hooked to ignition sw #11
Look for a rogue screw or other item short-circuiting the bus bar that runs between the glowplugs. Reattach the alleged glow plug feed at the ignition switch, then disconnect the power feed at the bus bar to prove the problem and the circuit. Last thought is a glowplug with a dead short. Plugs draw under 10 amps per. Current for EVERYTHING except the primary starter draw passes through a 30 amp fusible link, if that TC30 has the fusible link at the starter lug.
Good ideas. We can check power up untill the bus bar to check the switch and wireing. then past that it may be a shorted plug.
thanks for the ideas.
Soundguy
New/Unused CFG Industrial NT20-CZ Mini Excavator (A57453)
New/Unused CFG...
2013 HYUNDAI Veloster Hatchback (A56859)
2013 HYUNDAI...
JOHN DEERE 261 GROOMING MOWER (A52708)
JOHN DEERE 261...
2019 KENWORTH T800 DAYCAB (A58214)
2019 KENWORTH T800...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2005 CATERPILLAR 906 WHEEL LOADER (A52709)
2005 CATERPILLAR...
