TC33 Steering wheel
   / TC33 Steering wheel #1
day52
NH TCD33A
Had tree fall on steering wheel on my 33. Took top mechanism off, but couldn't get the wheel off. It is just a spline shaft, isn't it? I can't believe it would be threaded. Would a gear puller work perhaps? Don't want to cause more damage than I already have.
   / TC33 Steering wheel #2
The steering wheel is just splined, not threaded. Did you remove the nut on the center shaft that holds the steering wheel on? If that is done, then a good overnight soaking in PB Blaster or other penetrating oil and a 3-jawed gear puller is what you need. The nice thing is that if your steering wheel is already messed up, some cosmetic damage on removal won't matter.
Thanks jinman. That's pretty much what I thought. Steering wheel was toast anyway. Will try a gear puller after I check a couple buddies.
UNUSED FUTURE 13' 200 AMP JUMPER CABLES (A58376)
UNUSED FUTURE 13'...
Deere 350G LC (A53317)
JOHN DEERE 6000 SERIES BRUSHGUARD (A58375)
JOHN DEERE 6000...
LOT: Air Hose Reels, 220 V Cord, Electrical Cords, Hand Tools, 2-Wheel Hand Truck (A59076)
LOT: Air Hose...
2000 Cummins DGDB 100kW Standby Diesel Generator (A56857)
2000 Cummins DGDB...
2 POLY PIPE (A58216)
