dryflycaster
- Joined
- Jan 21, 2007
- Messages
- 22
The tractor was running fine when parked. I returned a couple days later to be greeted by what appeared
to be a completly dead battery.
There is absolutely no indication of power;
- The Battery is fully charged (15.7 Volts),
- I connected the Battery Charger and attempted to use the "200 Amp Start" feature (Still NOTHING),
- All Battery Cables are in good condition
- All Battery Cable connections are clean and tight,
- The Main Fuse has continuity and is good,
- There is absolutely no power indication at the dash,
- No Lights turn on (headlights, flashers or any other),
- Power is present at the Starter Solenoid,
- Power is being supplied "to" the Main Fuse,
- Power is "leaving" the Main Fuse,
- Ignition Key in "Off" position there is a hysteresis of approximately 5 V on the Heater Bus,
- Ignition Key in "On/Run" position there is 15.7 V on the Heater Bus,
- Ignition Key in "Heater" position there is 15.7 V on the Heater Bus,
-Turning the Ignition Switch to"Heater" produces no illumination of the Heater Light,
- All safety switches seem to be in their proper position (I have jogged the levers to check for a possible
misalignment, but have not done continuity checks of the switches,
- Safety Switch power connector by the rear axle is connected,
- Turning the Ignition Switch to "On" has no effect,
- Turning the Ignition Switch to "Start" also has no effect (no clicks, no engine cranking, NOTHING).
Everything is leaning towards the Ignition Switch, being either a bad switch or loose wire. I haven't checked the Ignition Switch out yet because it's such a PIA to access.
Any other thoughts before I tackle the Ignition Switch ?
