TC34DA Seat Safety Switch...?
   / TC34DA Seat Safety Switch...?
mjcbluridg said:
I took delivery of my TC34 this spring. A couple of months later, I was informed that there was a recall campaign for the operator presence (seat safety) switch. I believe that it related more to the issue of not killing the tractor when it should than to the issue of keeping the tractor running. The dealer came out and "fixed" it - installed a spacer and adjusted, I believe. Prior to the fix, I experienced the same issue as you - an overly sensitive seat safety switch (it would beep when I turned around to fiddle with something). I have only ran my tractor a few times since they fixed the switch, but I haven't had it beep at me since. Probably should discuss the issue with your dealer, make sure the recall issue is addressed, and see it they can adjust it to suit you.
AWESOME! Thanks man! That is great news to hear. I'll mention that to them... I would think that the parts guys would have access to TSB's err... at least that's what Honda guys call Technical Service Bulletin... I'll mention your situation to them, since it sounds EXACTLY what I'm going through... what a great place this is! Great forum!
The weather here in N.W. Ohio is warming up a little bit, hope you all are seeing some sun shine too! Thanks everyone… Maybe I’ll get some more work done in the barn today after all… :D
M.
michigander II said:
TC33DRon, Yes, now that you say it. Looks a lot like corrosion and could be the whole problem.
Max, You look like you have a nice home for that tractor of yours!:)
Michigander
Thanks bub! Yeah, she likes it in there... although we're still keeping the .22 Remington on stand by, I've since seen quite a few fat looking farm rats... ohs well... :rolleyes:
M.
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
2020 DRAGON ESP...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
2007 Freightliner (A57148)
2007 Freightliner...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
12FT X 20FT LIVESTOCK METAL SHED (A58216)
12FT X 20FT...
