tractorblue
Bronze Member
Hey Gents, Unfortunately need some expert advice AGAIN! Was mowing widows pasture the other day, was getting low on fuel but not in the red, was going down fairly steep incline and suddenly began to loose power and then died. Filled up with about 5 gallons hoping that was the problem. Engine would crank over but not fire up. Towed backed to the garage to work on. Very familiar and checked the PTO saftey switch (good) the seat switch I've already bypassed along time ago. I keep blowing #2 fuse. I've read about taking out the fuel solenoid and tried staring but nothing happens, I just keep blowing fuses (7 so far). I had also loosed the injector bolts to see if I could get fuel flow when I cranked the engine and little to none flowed. Not sure what the issues could be. I suspected a clogged fuel line at first but now with this #2 fuse blowing all the time my mind is blown. It was'nt blowing fuses at first. Turning over but not firing like no fuel. Need some help brothers!
