TC35D Rocker Shaft Removal
   / TC35D Rocker Shaft Removal #1
tc35dforme
Platinum Member
New England...Central MA
TC35D/16LA
Hey all, in the midst of a rebuild on TC35D. Rocker bracket( the cast housing that the rocker shaft and rockers mount on ) got damaged and I need to remove the rocker shaft and rocker arms in order to replace the housing. I cant figure out how to remove the shaft. Service book shows a set-crew, but I can't see anything. There is what appears to be a pin right next to the port where the oil pressure sensor lives. This looks like a locking pin, but its not appearing to be removable without a lot of beating. Anybody done a rocker shaft removal and can offer a solution ? Thanks.
   / TC35D Rocker Shaft Removal #2
Shaft will only come out from the left side on Shibauras. Index-mark lift arms and ram arm to the shaft for reinstallation to save trial & error when doing so. You may need a puller to remove arms. (Snap rings & spring washers that hold arms on are it) Tap the shaft out gently with a hammer. PM for details, a page or three, etc from WSM.
2016 Ford Explorer...
Parker 500 Grain Cart (A50774)
Parker 500 Grain...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
1270 (A50490)
1270 (A50490)
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
Informational Lot - Financing (A52748)
Informational Lot...
