TC40A shuttle shift failure/fix
   / TC40A shuttle shift failure/fix #1
nickel plate
Veteran Member
CA
2002 New Holland TC40S
I was ripping my up my 4000 s.f. vegetable garden plot and on the last pass I shifted in reverse to clear the tines then back into forward-NO. The shuttle lever just softly wig-waged as in broken. I pulled the lower left hand side black plastic cowling underneath the lever and found a very important punch pin that connects the larger in diameter long lever shaft to the smaller in diameter transmission stub shaft laying neatly on top of the manual transmission. Disastrous condition but and easy fix. For further non-issues of pin rejection I wrapped the newly re-installed pin with a hose clamp. Tools: You will need a very long 1/2" socket extension to remove the two bolts inside the engine cowling by the muffler. Heads up.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
CATERPILLAR 303.5 D CR EXCAVATOR (A51242)
CATERPILLAR 303.5...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
