TC40D Engine just stopped - Any help?
   / TC40D Engine just stopped - Any help? #11
mikim said:
replace it with a circuit breaker ... they may have to order it but it's in the parts book ....that one blows a lot ....
Any reason why it blows a lot?
Bob
   / TC40D Engine just stopped - Any help? #12
I even blows ont he big tractors.. My NH 7610s had it happen.
My gut feeling is that 7.5A is underrated for that circuit.. or to put it in a technical view.. it is correctly rated.. with no built in tolerance for lossin the system.. slightly low battery.. cold mornings.. corrosion.. etc.. All which can cause conditions like lower votlage.. that lead to higher current demands.. and thus.. blown fuses..
Yet another example of NH engineering at it's best.. probably the same guy in charge of engineering that circuit was the one who designed the breakable oil cooler lines for the mid HP units, as well as the one who ran all the fragile wires and connectors unprotected , under the tractor where a twig can pull it loose, and then leave you stranded out inthe wilderness... due to a spade terminal coming un-done...
Soundguy
   / TC40D Engine just stopped - Any help? #13
:) sounds about right to me ...... dunno why it does it - but there have been many on this site that have experienced it including me - Thanks to TBN when it happened to me I went straight for it -- easy fix and with the breaker in place - no more problems.:D
   / TC40D Engine just stopped - Any help? #14
Soundguy said:
I
Soundguy
I hear you, Bob
   / TC40D Engine just stopped - Any help? #15
I had the sme fuse on my TC40d . The wire running to the PTO switch was rubbing on the case underneith . Some electric tape good as new . Dave in PA
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
