TC40D PTO
   / TC40D PTO
the clutch IS disengaged.. IE.. not hyd pressured together.. it's the brake that's holding you up.
soundguy
Poor choice of words on my part, should have said brake.
Bud
   / TC40D PTO #12
I have the following routine for hooking up something like a finish mower
(1) Drop the lift arms below the hook up point
(2) Hook up left arm first. The arm can easily be lifted to desired point for hookup.
(3) Hook up right arm. Winding adjustment will handle needed adjustment.
(4) Hook up drive shaft. In the past I have used a bar to turn the drive shaft if needed. The last time I turned the tractor pto by hand. Assumed I learned something since it was easy to do. I always get my hands greasy anyway. I noticed others said they could not turn the pto by hand. I called myself doing that although mine is a DX 33 hydro stat.
(5) Hook up the top link and and adjust everything straight and level.
   / TC40D PTO #13
CNH Class II compacts have no PTO brake. No hassle PTO connection.
   / TC40D PTO #14
Used the ORC for nearly 1100 hours..........no problems, no frustration. Just keep in mind that there is no brake.......this has not been an issue for me.
My $.02
Gene
17101 (A53421)
17101 (A53421)
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
