Ballast TC45D/16LA Ballast
/ TC45D/16LA Ballast #1
burtrl
Ontario, CA
TC45D
I recently aquired a TC45 with 16LA loader. Rear turf tires are filled with Calcium. Despite this I still find the tractor light in the rear when working with the loader. Does anyone know what the recommended weight would be for adding ballast on the 3pt hitch? Thanks!
/ TC45D/16LA Ballast #2
I'm not sure if NH has any ballast spec for the 3PH. I think they recommend wheel weights. I just keep my boxblade on the rear. With loaded tires and the boxblade, I never have a ballast problem when doing loader work.
Welcome to TBN. I hope you enjoy your TC45D. It's interesting that you have turf tires on it. I don't ever think I've seen a TC45 with turfs.
/ TC45D/16LA Ballast #3
I use my big manure bucket from my TN75 on my TC (quick attach), it holds about 2/3 of a yard.
I can actually load it with enough sand (sand is heavy) to stall the loader.
Which means it's at 1650lbs (which is all the loader can lift)
and I rarely work with anything on the back, just the loaded tires. It can be a little tippy when it's heaped full with something heavy (1600+lbs), but that's a much bigger bucket than the usual 1/2 yard bucket.
/ TC45D/16LA Ballast #4
Burtrl,
I have a TC 40 with a 16LA and loaded R4 tires. I have the same trouble if I don't have something attached to the hitch. If the work space allows, I attach my medium duty 6' blade when i do a lot of heavy loader work. The blade weighs about 400lbs and this seems to help a great deal.
/ TC45D/16LA Ballast #5
i just bought a tc45da, it has 2 wheel weights per rear wheel which i think weigh 100 pounds each. will this be enough or should i get the tires loaded ?
/ TC45D/16LA Ballast #6
my tires are loaded but you can definately tell when i don't have my 1000lbs flail on the back or my backhoe...
i'd just stick an attachment on the back; box blade, scraper blade, etc....
if not a enough, there are some threads on here where people make their own ballast boxes with concrete, etc...
/ TC45D/16LA Ballast #7
I recommend getting the rear tires loaded. I resisted for many years having my rears loaded and several times had the rear tires in the air. Since I loaded my rear tires, I can't remember a single problem. I believe loaded tires adds over 800 lb to the rear wheels and that weight is not carried on the rear axle like any other kind of ballast unless you are in a situation where you need it (ie, holding down the rear). Then, the weight is felt on the rear axle as downward pressure, which is what you want.
/ TC45D/16LA Ballast #8
Another benefit of loading the rear tires is that you will be able to do alot of work in only 2wd instead of 4wd, saving wear on the front end, tires, turf, etc.
/ TC45D/16LA Ballast #9
This is an eternal debate, many just don't like loaded tires.
I have 3 tractors with loaded tires. My compact NH tractor scared the bejeebers out of me without loaded tires (I was pulling a wagon downhill, never mind the loader use!!!) and I have been driving tractors of all sizes for over 30 years, own 7 now. I had the tire fella out the next day & loaded them, much much better tractor ever since.
My 85 hp tractor has fluid in all 4 tires - no loader, the front end gets light pulling things, and I use the 3pt pretty good with picking up round bales, etc. As well I run this tall tractor through road ditches & hills round baling. It is nice to have it solidly on the groundwith the fluid on all 4 tires. The front tires probably hold as much fliud as some compacts....
--->Paul
/ TC45D/16LA Ballast #10
you can go up to 600 pounds on a draw bar 3 point hitch
NH part #718740616
/ TC45D/16LA Ballast #11
I'm a fan of the loaded tires also. I bought my TC40 with the two 105lb wheel weights on each side and that 420 lbs wasn't even close to being enough. Tried to move some stone around like that and it just felt like I was sitting on a spring board. Even driving in 2wd on slight inclines with a few inches of snow on the ground the rear would just spin. After a couple of months of that I had the rears loaded which added about another 400 lbs to each side and it now feels like a tractor that is stuck to the ground, like I'm used to. It can still get light doing some loader or grapple work but at least I feel safe now, plus if I have the room I just add my scraper blade to the back, probably only a few hundred pounds but it's always been enough.
Thanks for the feedback eveyone! Since the heaviest implement I have is a rock rake (not very heavy) I have decided to make a concrete ballast. My last tractor had about 800 lbs of concrete on the back & it worked great.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 POLARIS RANGER 400 H.O. RTV (A60430)
2011 POLARIS...
2014 VOLVO A40G WATER TRUCK (A60429)
2014 VOLVO A40G...
Zato Hydraulic Demolition Shears Excavator Attachment (A59228)
Zato Hydraulic...
UNUSED FUTURE 32"...
2024 KAUFMAN LOPRO WEDGE 3 CAR TRAILER (A59905)
2024 KAUFMAN LOPRO...
