tc45d creeps
   / tc45d creeps
sorry i was having a senior moment
   / tc45d creeps #12
. just in case it isnt, can i adjust the spring tenstioner to get the roller centered?. thanks for the help
Blake
This thread is an oldie, but covers the full description of the problem (as I see it), JInman's difficulties with the swash plate, and others comment about similar problems. I suspect that you will be able to get the required results by adjusting the tension on the spring, and RickB has commented in other threads that you may be near the end of the available threads on the adjustment to get it to work. Just in case it doesn't give enough adjustment, post #47 is Spencer200's part number for a replacement spring that has more "spring". It is a pre-forum-upgrade thread so you won't get the smileys and emoticons, but the information is still relevent:
HST just wont stop quit
The thread also discusses the phenomenon of the HST pedal not wanting to return to neutral position when pulling a heavy load with low RPM. This involves the Charge Pump not developing enough pressure at low engine RPMs to return the transmission to neutral.
   / tc45d creeps #13
OK, i found the nut it has a small bolt in the center of it, both were not very tight. I loosened the bolt and turned the nut a little at a time until there wasnt any creeping .I dont think it was even a quarter turn.I tightend the center bolt and no more creeping.I will check the roller tomorrow to see if it is centered. just in case it isnt, can i adjust the spring tenstioner to get the roller centered?. thanks for the help
Blake
Blake, DocHeb gave you the full course answer. I suspect if you have to adjust the spring tension a little, it wouldn't hurt. Just make sure everthing is free and not having problems from friction. You've done a nice job of fixing a nagging problem. Too bad you missed the opportunity for a sale. Maybe you can contact that person again and have them take a second look. Hope so. . .
   / tc45d creeps
Thanks to all and the tbn site . you guys are awsome.
Have a great holiday
Blake
ps I put the chains on yesterday. that should keep the snow away for awhile!
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
2007 Volvo VNL Truck Tractor (A52748)
2007 Volvo VNL...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
2015 Jeep Cherokee Latitude SUV (A50324)
2015 Jeep Cherokee...
