TC45D - issues/questions
   / TC45D - issues/questions #11
Jim,
I think my list is similiar, and I didn't search for duplications between your list and mine.
I have a .txt file that lists all the problems (that didn't seem like one-time occurances) that were described since 2001 when I joined TBN. My text file was great since I could cut&paste the problem description along with links to the "definitive solution" threads, however with the forum upgrade last year none of my old links work. :mad: I also have had less success with the new search function, so the work of trying to re-establish current links outweigh the benefits to me, but I will on occasion search again and find the old links (like the thermostat picture above) to help somebody.
This is the list I was following:
1. Battery offgasing causing corrosion around battery and cooler. ( Some of us have gone to sealed batteries ala Optima)
2. No-joy joystick breaking at the screw hole for handle. New part engineered differently and fixes the problem.
3. Low-temp running due to flow bypass at common coolant drain line. I think this solution just covers up for the occurance of #4.
4. Low-temp running due to defective thermostat with "dingle-ball" that jams and keeps thermostat open.
5. Coolant leak at fitting adjacent to oil filter ( Requires new part or reinstallation with high grade thread sealant )
6. Sticky/sluggish hydro pedals. Operating at higher RPM helps, and there is a repair kit with higher tension springs available.
7. Water getting into tilt-wheel mechanism/piston causing failure.
8. Starter fuse (7.5 Amp) blowing, PTO light remains on, repair is replacement of fuse with an 8 Amp circuit breaker.
9. Instrument panel fogging up. Mentioned multiple times in multiple threads. Mostly an annoyance. No specific fix ever described - some owners have had the panel replaced.
10. HST pedal plate inadequately welded (JInman's Syndrome)
11. Lower 3-pt arms made low-grade steel, bending under load, especially with backward movememtns. Being replaced under warranty by New Holland, involves serial numbers < g508677.
11. Sudden failure of Transmission Hydraulic Pump, resulting in no HST motion and no PTO rotation, yet engine runs well. Relates to coupling between the engine and the transmission charge pump. (DocHeb's syndrome)
12 HST pops out of gear going downhill (part of a recall by NH of ~1600 early production Class III Boomers).
13. Leaking hydrostatic test ports on transmission casing (below the tractor seat), caused by lack of thread sealant.
14. A 'pth, pth, pth noise" or chatter from HST Cooler Check Valve (located on the top of the HST Filter ) - a "normal noise that occurs when the HST oil is cool." No repair is necessary.
15. Leak in Class III hydraulic oil coolers at hose bib attachment to top of cooler. Re-engineered cooler resolves the problem.
16. PTO Brake problems for serial numbers after G524944 to approximately G604974, recall campaign 000250.
17. Loss of 4WD in Class III Boomers:
Lock nut for pinion gear in front gearcase not secured properly, causing sudden loss of 4WD.
18. Cold weather blowout of the "O-ring" on the hydro filter (all Boomer tractors and Case equivalents). Design change (since March 2004) in HST charge system results in increased pressures in filter, resulting in blown out O-ring on HST filters, especially in cold weather. New Holland sells a replacement "cold weather" filter for $60.
   / TC45D - issues/questions #12
kloswerkes said:
You mentioned "One other thing. You posted the same question in two different forums.". I did a bunch of posting yesterday, and if I did that, then it was unintentional and I apologize.
I was referring to this post in NH Buying/Pricing:
"They delivered the TC45D and 6` snowblower today.
The delivery truck got stuck and I had to pull it out!
I drove it for about 1/2 hour. Temp was around 9 degrees.
The temp guage might not be working, as it never moved.
There was another issue with the hydraulics, or something,
as every few seconds you could feel like a thump.
From behind the tractor, you could actually see the 6ft snowblower move up and down when this happens.
I stopped while driving up a hill.
I then switched to turtle, and the tractor wouldn't move.
The more I increased pressure on the pedal, the more the engine would bog down.
The only way I could get it to move was by switching to rabbit.
Tried this twice just to make sure it wasn't a fluke.
I'll ask on the owning/operating forum and see if anyone has any advice."
It's not a big thing to me, but it is the the same question in two separate forums as you noted in your last sentence.;) Don't worry, I've probably been guilty of the same thing at some point over the years.:eek:
Well, that was my fault......I felt bad because everyone had been so helpful responding,
and it seemed like I wasn't statusing where everything was.
Didn't want anyone to think I didn't appreciate the assistance....
So, it was meant more as a "Here is where everything is at in this purchase process."
And since it had already been delivered, I figured I was into the owning / operating phase,
and should ask what to do about the issues over there, since they weren't purchase related.
Sorry for the confusion/clutter..... :eek:
   / TC45D - issues/questions #14
Jinman and DocHeb
Now that you two have given the list, some of the less experienced people ought to do the searches and make the links. I don't have time now, but will in a couple of weeks, but I would be happy to let someone else do the link searching and posting.
If there are other lists by other people, as I am sure there are, please chime in.
A consolidated list of nice features adds, such as battery cases, and adding remotes, and grapples, and TNT and and and would also be good and useful. I would not ask someone to provide the links, just make a list, and let someone who wants to learn do the background stuff.
Chris
   / TC45D - issues/questions #15
Since I'm considering a TC45DA I've been doing some general searches about them. Maybe it's just because I'm a novice with tractors, but this thread dampened my enthusiasm a bit.
   / TC45D - issues/questions #16
This thread reinforces that fact that tractors are mechanical devices that will eventually fail given enough time or stress. Threads in this forum (and the entire TBN board) will give a biased view of the rate of failure. Nobody posts that "today was another day and everything was fine." New Holland tractors have a reliability rate that is equal to all those other tractors out there. Don't be dampened, be dry and happy.:D
   / TC45D - issues/questions #17
In my opinion, this list shouldn't dappen your enthusiasm one bit. If you look through the list, non of the non-recall items are major. I have a 2000 model, purchased last year, and I really like it. I really like it!
If you were able to get an objective perspective from owners of other brands, I am quite sure the list would be about the same size, with about the same levels of issues. It is unlikely you could a list from them.
Many of the other brand forums eat their young if they talk about a problem. That is what is so good about NH owners here. They are confidant enough in their tractors to speak, listen, and help if they can.
Anyway, I would look at the list objectively, and come to your own conclusion. If you buy used, the list is a good checklist for problems to look for. If you buy new, the items on the list have mainly been fixed.
Chris
   / TC45D - issues/questions #20
We have a TC45DA.
Instrument Panel will not light until engine started.
We've changed battery, ignition switch and checked all fuses.
Problem remains. Any suggestions ?
(Can't read glow plug light - not good)
Freightliner Tender Truck - Adams Tender (A56436)
Freightliner...
2021 TAKEUCHI  TB260 (A58216)
2021 TAKEUCHI...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
1605 (A57192)
1605 (A57192)
2013 Ford F750 Single Axle Dump (A55272)
2013 Ford F750...
John Deere MX8 Rotary Cutter (A57454)
John Deere MX8...
