kferris said:On saturday I looked at a 2310 (TC40 W/ a cab).
27,920 Tractor only
3640 for a 250 TL Loader
2966 for a Rhino TM84 Turbo rear finish mower
3293 for a New Holland rear snowblower
1200 for 2 rear remote valves for blower function
Total with Tax 40,970.00
Does this seam high? Seams expensive.............
kferris said:Jim,
Unfortunately I'm sure. It seamed a little high. Does it seam like it's 7 grand high even with the factory cab and HST?
jinman said:For a 6' cutter, the 40DA will be fine. If you were buying a gear tractor instead of HST, then you would get more benefit from the TC45, but with an HST, you'll never know the difference. Now, the N844L engine in the TC45 is a very strong engine that is used in other NH applications and even turbocharged in some of those. It's a strong engine. However, the N844 engine in the TC40 is basically the same engine with a shorter stroke, so it is also a very good engine. You will be happy with either.
dknarnd said:The optimum size cutter for either one of these tractors is 6' but with the 40 and HST you are at the very bottom, or below, the standard thiking of needed PTO hp for a 6' cutter.
