TC45DA radiator replacement - anyone want to share tips?
   / TC45DA radiator replacement - anyone want to share tips? #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
It appears I'm on the verge of having to pull the radiator on my TC45DA as there's apparently a leak in it somewhere as small pools of green pee seem to form under the tractor after a day or so and I'm comfortable it's not a hose connection... It's clearly somewhere on the radiator itself based on where the coolant is dripping from.
Anyhow - next step will be to drain and then pull the radiator... Doesn't looks too bad over all, few bolts on top for the overflow, a few on the back holding it to the fan cowling, a bit of maneuvering around the hydraulic cooler and 2 big bolts on the bottom that hold it in place... Hoses disconnected - looks like a lift out...
Anyone done this? What am I missing, what tool was the "I need that" moment? What are the hidden tricks and unreachable bolt moments?
I learned long ago the experience here is worth it's weight in gold and all you have to do is ask!
Thanks in advance.
   / TC45DA radiator replacement - anyone want to share tips? #2
Do find the leak first!!!! Hate to see it be a water pump!
   / TC45DA radiator replacement - anyone want to share tips? #3
check the coolant drain valve along the frame . I had one leak on a tc35d until I took it out. The one on my farmall40 drips occasionally. lt190b
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2006 CHEVROLET EXPRESS SERVICE VAN (A51219)
2006 CHEVROLET...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
