TC55, how do you pull the instrument cluster?
   / TC55, how do you pull the instrument cluster?
http://www.tractorhouse.com/images/Tractor/fullsize/73340619.jpg
This is a tc55, but the instrument panel is exactly the same as my dx55. The OPERATOR'S MANUAL says to loosen the two screws to remove the panel.
WHAT TWO SCREWS?????!!!!
I assume they are behind the black bezel, but like yall said, im not pulling on anything until i know for sure.
   / TC55, how do you pull the instrument cluster? #12
This was easy on a tc40d there was two screws to each side of the front of the cluster in the black band in plain site .The cluster was removed in one piece on the 40.If the black band around the cluster doesnt have two screws it must have them from behind the dash .I will look on my tc55 to see if it is the same.Also i looked on the case/nh website under part's the tractor is shown in detail execpt for those two screws .The cluster has a glass cover acording to the diagram i looked at.It looks like if you remove the cover you have access to the cluster .The glass cover might snap in place but i would get the dealer to tell you as you dont want broken part's.My tractor is not here today but i will find out for you.The diagram also showed 4 switches operating all the light's at the case website under searching for part's.
Cool, thanks. The switches are another inconsistency. I have yet to see a DX55, including my own that has 4 switches. They have 3 and a blank space.
   / TC55, how do you pull the instrument cluster? #14
The tc55 has different looking light's on the front of it mabe that's why they only have three swiches.
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2020 ASV RT-120 FORESTRY SKID STEER (A52709)
2020 ASV RT-120...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
