Boomerang1
Weight behind the rear axle has nothing to do with weight transfer. The front axle is the fulcrum. If you had enough weight in the bucket so the rear tires were 1/2'' off the ground, all the weight of the machine and load (gross weight) would be on the front axle. If you add weight at any point behind the front axle you are transfering weight to the rear of the machine. Try this for yourself. Pick up a load so the rear tires lift off the ground and let the tractor balance that way, set the park brake and dismount the tractor. What do you think would happen?
(In the following example the teeter totter fulcrum represents the tractor font axle and the weight on the end represents the tractor rear axle.)
Balance a teeter totter with a 100# weight on each end. Add a 100# weight to one end at any point between the fulcrum and the original 100# weight. The heavy end will drop. But, If you didn't move the weight towards the end far enough to make the heavy end touch the gound, the fulcrum will still be carrying the gross weight of the teeter totter. If you move the weight far enough so the heavy end is now resting on the ground, the gross weight is shared by the fulcrum and the weight on the end wich is resting on the ground.This means that the fulcrum now has less weight on it because the gross weight is being shared by two points. Plus there is still a 100# weight on the end that is in the air. (This 100# weight could represent the loaded bucket.) At no time did we extend the length of the teeter totter to acheive weight transfer.
Some of you may be thinking of effective weight transfer. The further the weight is moved to the rear, the more effect it has. That is why a 450# weight hung from the 3 point hitch arms gives an effective weight of 600#s
Remember, when you start adding weight behind the rear axle, the rear axle now becomes the fulcrum. Believe it or not.
