TD5030 Differentiall Lock Stuck On
   / TD5030 Differentiall Lock Stuck On #11
I see many shafts that enter the trans cases freeze up or turn hard from rust. They like to design these things with the oil seal on the inside vs the outside which allows rust to form between the shaft and bore. Get some good penetrating fluid and lube where the pivoting shafts go through any bushings or into the cases.
Yeah, I took it partially apart before winter and rust on the shaft was what damaged the seals. I polished it up with emory cloth but, the seals were already boogered up too bad. I ordered a new shaft and seals and will replace it all in the spring when the weather warms up. All the hydraulic fluid has to be drained and the piece the shaft runs through removed to get the seals out. What a crappy design. A lot of the other new Holland tractors the seal housing just unbolts from the side of the transmission.
   / TD5030 Differentiall Lock Stuck On #12
In the fall I wash my tractor down getting all grit and dirt off and let dry for day then grease gun and spray can full of any cheap oil. Every nut bolt and shaft get a shot or two of oil and brushed around. It makes things way easier to take apart and less small problems.
34" EXCAVATOR BUCKET (A57192)
34" EXCAVATOR...
1996 JCB 506B Telehandler (A57024)
1996 JCB 506B...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
6-Band Wooden Barrel (A55853)
6-Band Wooden...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
UNUSED FUTURE FT-LJB12 POLYTHYLENE BOARD (A57193)
UNUSED FUTURE...
