Tearing down an old barn
   / Tearing down an old barn #11
Well...after having seen the picture it appears like it's time for a little tractor action. I don't see any reason why you can't just work your way around the perimeter of the barn pushing the sides in to get it down. Keep in mind that some of your posts appear to be buried but the age of the barn looks like you'll be able to take every thing down and then cut the posts at ground level if you don't want to remove them.
   / Tearing down an old barn #12
I had an old barn with a loft that had partially collapsed. I rented a skid steer, started pushing it down around the edges and then ran over it a few times to crush and compact it and pushed it up. Hauled it to a deep gulley and buried it.
   / Tearing down an old barn #13
When I bought my land I found an old barn in the trees. They had grown up around it over the years and there's no telling how old it was or what it was used for.
It was 100 ft long by 40 feet wide with 14 ft walls. To say it was pretty big is an understatement. At first I thought I'd try and rebuild it, but one day a large oak branch fell through the roof and caved just about the entire roof in. That's when I decided it was too dangerous to mess with.
I first tried to push it down with my FEL, but it wouldn't budge. I have a full size 555E backhoe, so I switched directions and tried with the hoe stick.
I had to hit the walls near the top to get any results. Allot of those poles were still solid and ended up snapping way up high. A few times I had splinters of wood fly by my head close enough to scare me pretty good.
Wear a hard hat and saftey goggles!!!!!!!!!!!!
Another pucker factor would occur when I'd get a hold of a section of wall. I'd be pusing on it and it would be falling apart, only to hit a solid part. Then my hoe stick would lift the backend of my tractor up into the air. This is particular scarry when I was at an angle to the wall.
Then there was the few times I used my FEL to try pushing over sections of the wall. I was relying on brute force and probably was going about it all wrong, but I'd drive up to a section with the FEL up fairly high with the intention of pushing it down. Same thing would happen. It would start to collapse, then catch on a strong timber or something. This would lift me in the air and if I was at a bad angle, it would scare me fairly good.
Of course, that barn was on the side of a hill and sourounded by large oaks making access tricky.
Whatever you do, go at it real slow and just nibble away at it. I was too aggressive and put myself in too many situations that caution and intellegence should have avoided.
Good luck and be careful,
Eddie
   / Tearing down an old barn #14
This looks like a couple hour job for an excavader with a thumb on it.
I had a small barn taken down to build a new one.
The excavader knocked it down, broke it up and loaded in into roll-offs.
I would dig a hole next to it and knock it down into the hole.
Burn it in the hole and cover up after the ash cools completely.
This way there isn't the settling problems with the soil.
Regards,
Chris
   / Tearing down an old barn #15
I was thinking the same thing......would be a pretty fun "project" too /forums/images/graemlins/smile.gif Just make sure to get a real excavator and not try to skimp with one of those little trenching units.
   / Tearing down an old barn #16
You should have no problem knocking that stucture down with a FEL. Anyone trying to take down a two story post and beam barn with a FEL is nuts. The easiest way to do them is by knocking out a few pins, attaching a longgggg chain to a lower post and pulling the barn apart. A better way is to call the local fire dept and ask if they are interested in a real life barn burning training sessions.
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
John Deere 652R (A50121)
John Deere 652R...
2002 International 9200i Truck (A52748)
2002 International...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
