Technique to weld DOM tube to flat plate
   / Technique to weld DOM tube to flat plate #21
Those aren't going anywhere!!!! :)
This was before final welding just to make sure everything was working OK. Just showing you the concept.
   / Technique to weld DOM tube to flat plate #23
That's definitely the way to do it. Gives you the best chance of the tubes staying parallel. :thumbsup:
   / Technique to weld DOM tube to flat plate #24
Some of the higher end welders have adjustable arc length correction that is wonderful for doing the job you just did. It makes it look like you had the tip right at the puddle even though you were an inch away just a point to ponder.
Spatter comes from a dozen different reasons. Your project turned out and the spatter can be dealt with. Looks Solid !
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Lot 58 Valves Sold times the money 19x (A59213)
Lot 58 Valves Sold...
Topcat Drum Mulcher (A57149)
Topcat Drum...
