teeth cut off backhoe bucket best options?
   / teeth cut off backhoe bucket best options? #1
disney
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
Greetings everyone. I recently acquired this bucket, and someone did me the displeasure of cutting off all the teeth. I do have several buckets, but as this is the smallest size I can use with the thumb installed, I would really like to have some teeth on this one. What are my options for adding teeth? I do have a hypertherm 65 plasma, but these might be too thick for even that. And cutting the end pair might be hard to remove without cutting through the side of the bucket. Open to any ideas other than buying a new bucket, or spending the rest of my life filing these down with a hand file.
   / teeth cut off backhoe bucket best options? #2
Air carbon arc cutting is what I would do. You can remove the weld and pull the part out without damaging the bucket
I takes a little practice but it's easy and once you get good at it it moves quick
   / teeth cut off backhoe bucket best options? #3
That would be my most readily available first choice also.
Ideally an oxy-exothermic lance if you have access to one.
   / teeth cut off backhoe bucket best options? #4
Call heavyquip and get some teeth. You're just missing the teeth. That part stays on the bucket. Teeth are replacement items.
   / teeth cut off backhoe bucket best options? #5
It would appear that what you have is the mounts for replaceable teeth.
You should be able to find new teeth to fit those tooth mounts.
   / teeth cut off backhoe bucket best options? #6
I’d cut the whole cutting edge off the bottom and replace it or if I didn’t want to go through that much work I’d just weld new teeth beside the old ones.
   / teeth cut off backhoe bucket best options? #7
Common folk with old school tools and a bit of talent would use an oxy-acetylene torch to cut the old shanks off. Then stick weld new shanks on that accept the tooth style of your choice.
   / teeth cut off backhoe bucket best options? #8
Your hypertherm plasma cutter can cleanly gouge out the welds of the old shanks with the right nozzle and settings. Check your manual or online. Rated removing pounds per hour so will not take long. Hypertherm has great customer service and will help you with information. They make flush cut and hyaccess nozzle consumables too. Then weld whatever shanks and teeth you want.
   / teeth cut off backhoe bucket best options? #10
You need bucket teeth and shanks. You can prob cut the weld right at the bucket. Trying to save the cutting edge that's in the shank is going to take forever I think.
You could buy shanks and a section of cutting edge then just cut the whole edge off and start over.
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55314)
2023 Unverferth...
CATERPILLAR 259D3 SKID STEER (A52707)
CATERPILLAR 259D3...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2024 KMC 7406 (A53084)
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
