Telescopic draft links problem
   / Telescopic draft links problem
Maybe giving it a shot of graphite might help? (The powder kind.)
   / Telescopic draft links problem #22
   / Telescopic draft links problem #23
Without reading back over all of it, are you pinning your stabilizers before trying to lock the slides in? I'd try leaving them unpinned and pin them after they slide in.
No, I leave the stabilizers unpinned until everything is hooked up
   / Telescopic draft links problem #25
On our L3830 I usually just lift the 3 point and they drop into place. Sometimes I have to push the bushhog back and forth, but its not a big deal.
Aaron Z
Same here. I lift the three point on order to center the implement and put the pins in the sway bars. Thats when I pop the lift arms back into place.
   / Telescopic draft links problem #26
I put some PB blaster in mine on occasion.
D.
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
2011 Kubota M7040SUD 68HP 4WD Utility Loader Tractor (A49461)
2011 Kubota...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
