Temp Gauge
   / Temp Gauge #1
Dsavage
Maine
Satoh S470D Buck
Hey guys,
My old Electric temp gauge hasn't worked since I bought the tractor. So I replaced it with a Mech. one.
Question is, the gauge I bought doesn't threat into the block/tractor.
Are these Metric thread.? I'm guessing yes. and I'm not 100% sure what I bought, I didn't even look at the thread one the package.
   / Temp Gauge #2
I put one on the grey beaver (1450). It came with adapters. I didn't have to remove the electric one, I found another port in the water pump. It had an allen plug in it. The sender screwed right in. Will probably put one on the Buck too.
   / Temp Gauge
ahhhhh I think I may have seen that..! So just plug the other one eh.?
   / Temp Gauge #4
I think the ports are standard NPT (national pipe thread) - at least I know NPT fittings will seal-up in them.
   / Temp Gauge
I'll have to check.. It seemed to thread in about one or two turns and stop.. I didn't want to force it.
   / Temp Gauge #6
Some Jap motors use British pipe thread for the senders and you need an adapter.
   / Temp Gauge #7
That is true for the oil pressure switch. Valley Power gave the the part # for the adapter and I bought one at O'Reilly. I'm not sure about the temp though, the gauge I bought had adapters with it.
   / Temp Gauge #8
Looking at another thread on this, the threads for both ports should be 3/8 npt. The oil pressure switch port adapter part number is eddleman 265220.
2020 FREIGHTLINER M2 106 26' BOX TRUCK (A54607)
2020 FREIGHTLINER...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55218)
2012 RAM 5500...
