Temperature gauge
   / Temperature gauge #1
sandman2234
Super Member
Jacksonville, Florida
JD2555 and a few Allis Chalmers and now one Kubota
My JD 2555 is no spring chicken, and a lot of the wiring and most of the instruments don't work. Probably due to the company hiring inexperienced mechanics and they doing what it took to make it run, daylight hours only.
Temperature gauge and fuel gauge seem to work, but not sure. I have never ran it out of fuel, but that might be luck. I did noticed the temperature gauge spiking yesterday. I shut if off, and started looking it over. No signs of overheating, engine really wasn't that hot(?) to the touch, no steam anywhere, or other of the usual signs of overheating. Due to the wiring on the tractor, I wonder if I am getting a false reading.
Anyone have any ideas on the best way to install a direct reading temp guage?
Thanks, David from jax
   / Temperature gauge #2
The best place to mount it would be to remove the sending unit from the left rear corner of the cylinder head, and install a mechanical gauge from an earlier model 2440. It should fit the head, but you will need to find a place to mount it in the dash.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
40' CONTAINER (A51244)
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
