Termites or ???????????
   / Termites or ???????????
Look closer, the termites are only in the door frame, not the post. (I hope)
   / Termites or ??????????? #22
I put a new steel door on the back of my country house back in late 1988, then removed it in 2002 and replaced it with a wider one. Hung the older door on the north side of my garage back then and after 28 years of shaded use, last year the bottom part of the frame finally began rotting out. Your images appear a lot worse than what my old door looks like now.
   / Termites or ??????????? #23
Yeah, I doubt the termites are into the treated column (now wood bees are another story -- they will bore into treated wood with no distinction).
Those door jambs are an easy target for rot and infestation. Typically they are made of a soft white wood and may as well be considered moisture/termite "bait".
I was interested to see that on our new house, all the Therma-Tru door jambs had the bottom 3-4" made of a composite material to avoid this common problem.
2017 Ford F-450 Auto Crane 5005EH Crane Truck (A59230)
2017 Ford F-450...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
